Connector disconnect...
mikiedreb
Benicia, California
Quick question......is there any trick to disconnecting the main EEC wiring harness at the firewall? As you untighten the bolt, is the connector drawn from the plug, or do you yank?
Thanks
Mike
92MTX
shojuan
sunny San Juan Bautista,
I've never disconnected my ECU, but I know that when you undo the bolt on the ICRM connector just above the radiator that the connector is drawn away from the ICRM as you loosen the bolt. No yanking required or desired.
rktmn
Well-Known Member
miami
Just loosen the bolt and wiggle the connector out.
If you want to remove the EEC computer itself, go in through the glove compartment, remove the rear screws, and push in from the engine compartment into the dash.
Jose
