Computer(ECU)
vamadcap
Kearney, Nebraska
Im trying to remember when you remove the computer, its located behind the glove compartment right? a couple bolts hold it in? Im gonna swap computers some time this week and was trying to remember how it all went together.
ThatShoGuy
michigan
if the ecu is the same as a pcm.. i doubt but its behind the engine in the fire wall...
NebraskaSHO
Harumph!
Omaha
Computer is behind the engine tucked into the firewall. There should be some screws that hold it onto the panel.
Where have you been man!?!
Two 11 mm nuts hold the rubber grommet on and a 10 mm bolt holds the wiring connector on. It helps to take the cowling off on the passenger side.
vamadcap
Kearney, Nebraska
pcm yeah...i couldnt remember and for sum reason ecu popped into my head. Thanks paul for the tip. nebsho well it started with a move, and a new roommate, then no internet yet...so then i have to borrow the gfs computer to do my online stuffs so i dont get much done the few min im on. then tack on recovering from sugery to repair a double hernia from work...so ive been around but not...
