94shodriver
I just finished a complete rebuild and 3.0 to 3.2 swap. Everything is new, save for the rings and valve guides, I used the 3.2 heads with the 3.0 intake cams. After installing the engine, filling it with fluids, and test starting it, it quickly began to idle worse and worse until it would not run any more (maybe 3 minutes total). My helper said he put 4 gallons of coolant in the radiator before start up. Now the crankcase is full of coolant and oil. The radiator is low, too low to see if there is any oil in it. There are no external leaks. The only places that I can think of for a leak are the head gaskets and the oil cooler. I was very careful to clean the block (hot tanked) and the heads, in addition to cleaning out the head bolt threads and head bolt holes in the block. I double checked the torque on the bolts for each torque value. I checked on-line to make sure that I ordered 3.2 head gaskets, and I did not notice any discrepancies during installation.
Unless anyone knows of any other areas to troubleshoot, my course of action is to drain the fluids, remove the oil cooler and check for an internal coolant leak, then to do a compression test on the cylinders.
Has anyone ever had a similar experience? Advice?
Thanks,
Ian
Thanks,
Ian
