Storm-Chaser
Is there any crud on the top of the battery? I had one instance where the crud on top of the battery was allowing minor current flow across the top of the battery, discharging it over time. If one of the battery posts or caps is venting gas, it will create a conductive coating on the top of the battery, which will accumulate dirt/dust and become that black crud you see on top.
Are all batteries the same - yes and no.
Have you had the battery load tested? If it is marginal, the combination of a continuous minor draw, short trips with the UDPs, and cold-soaking at night may be what's killing it.
I'd try what itwonder and SHOZ123 have posted. First night, disconnect the battery overnight and see if it starts - that will eliminate the battery as a direct cause. Second night, pull the ignition cylinder. Third night the power feed for the car alarm. Fourth night engine compartment fuses for the HOT in ACC power feeds. Fifth night fuses for HOT in RUN.
hawkeye18 also brings up something to consider - the Remote Keyless Entry Module (RKEM). Several have posted in the past a range of funny electrical things that happen when the module goes bad - and that's the same module that should time-out and shutoff interior courtesy lighting after 45 minutes . . . .
My understanding is that the underhood light is switched by an internal gravity switch inside the small light housing. The glove box light by a mechanical switch in the glove box latching mechanism, and the rear trunk light by the small mercury-switch on the left trunk hinge (that small black cylinder on the harness leading into the rear deck lid).
Oh, 1A = 1000mA. So 500mA = .5A !
We promise we won't tell your boss . . . .
