cold running SHO?
SHOstopper
Burlington, MA, United States
does this qualify for a cold running sho hwne i start my 90 mtx up the temp guage is at all the way to the bottom in the blue and about 10-15 minutes of driving it begins to climb but i still have heat, is there a way to fix that or is that just a sensor problem
fricker66
You might have a t-stat that is stuck open. This happened to mine a few years back and during the winter the temp gauge never moved past top of cold. I still had heat, just not very hot. Replaced it but gauge still takes a long time (5 min)to reach operating temps. I'm interested in seeing other posts on this topic. Seems like the newer cars reach operating temps much much quicker. My wifes Infiniti will reach its temp before we go 1/4 mile. What causes this in the newer cars?
Frederick Ricker
89 Black/Grey w/ 81k mi
91 Slicers, 190lph pump
[This message has been edited by fricker66 (edited 02-07-2002).]
Bizzy
Just like mine. I need a t-stat. Heat comes on, but not hot like it should be. Most of the time that's ok with me cause I like it cooler anyhow, but on 7° days it really sucks. In any case it's a relatively simple fix. Just make sure your autoparts store gives you the correct t-stat.
SHO's are like kids...they test your patience but you gotta love 'em!
Beth
'91 Plus MTX, Mostly stock
K&N Filter, Coneless
Colgan Custom Bra
Racing Series Driving Lights
Mods in the works
Many items on wish list!
Shoman94
Maine
And don't forget it makes your SHO run in the warm up mode all the time. Bad for the cats and poor fuel economy.
'94 MTX Silver
Tokico Struts, Eibach Springs, Spmotorsports SubFrame Conn. 29mm ShoShop Rear sway bar, Shohop Cat back, Gutted box with K&N, '96 Brake Upgrade, White Face Guages.
[This message has been edited by Shoman94 (edited 02-07-2002).]
Shoman94
Maine
oops...double post
'94 MTX Silver
Bizzy
I really gotta get that fixed fast. That's probably the biggest reason my fuel economy sucks. I don't suppose it could have anything to do with how I drive could it??
Beth
Colgan Custom Bra
Mods in the works
CTOESHO
DeKalb, IL, USA
Is it bad for the temp gauge to be that low all the time? Like on mine, the gauge is below the "l" in normal all the time unless i'm sitting in traffic, but once I start moving, it lowers back to under the "l". My fuel economy is still around 21 mpg, but I'm also running rich and have a bad ACT.
Mike
93mtx
Bizzy
I don't know that it would be bad for the engine or not but Shoman94 says it's bad on the cats. My car doesn't seem to have any other problems caused by it, other than the lowered gas economy and the lack of nice warm air on really cold days. I'd say you'd be in really bad shape though if it were stuck shut which would cause overheating of the engine. That's the real killer.
Beth
Colgan Custom Bra
Mods in the works
