Codes
iKevin
CT
Ok so while driving the car today the CEL came on for about 30 sec went off then came back on agian for another 30 sec then about 5 min later came back on and stayed on..
did the paper clip thing and recorded it.
http://www.youtube.com/watch?v=NE03tIlCNVc
I know its late, but I can't count those pulses with the camera moving all over like that.....
can you try it again and just hold the camera steady?
so I count these:
koeo
551 - iac circuit failure
stored
122 - tps circuit below minimum
157 - mafs circuit below minimum
158 - mafs circuit above maximum
176 - left bank lean
542 - secondary fuel pump circuit failure
543 - secondary fuel pump circuit failure
the fact that its complaining about iac, tps, and mafs voltages suggests that there is a wiring problem, since all of those are on the same circuit - I would carefully check connectors and wiring for those.
left bank lean is usually a 02 sensor issue, but can be a bad injector or a vacuum leak too. your symptom of the cel on for a while then off again is common for a bad 02 sensor, so that is a serious suspect.
the fuel pump stuff is junk and should be disregarded.
I would reset codes, and drive it a day or two, and see if you get the same codes or if some of them are old.
