Clutch/Transmission Issue - Looking for Help!
fricker66
I've been noticing an issue with my 89 for several months now and the issue has gotten progressively more consistent and caused a strange "death" sound while driving home on Friday. It is my daily driver so I'm looking for expert insight as to a likely cause so that I can attempt to minimize down-time or perhaps make a final judgement call on having an 18 year old car for the daily commute. Here's the background:
Winter of 2003, Steve "projectSHO89" replaced the clutch and blocking rings in the all original 89 drivetrain (9.75" clutch upgrade was performed by dealership). Factory clutch replacement kit was purchased from Mark Nunnally. Also opted for the ceramic TOB from SHONUT. This was right at 100k and car now has 135k.
Several months ago I started noticing an issue with getting 1st gear to engage after backing out of a parking spot at my son's school. A quick shift into 2nd, release of the clutch to begin forward movement and I could get the shifter into 1st. Never any grinding, just felt "blocked" out of 1st. No grinding into reverse either. It was sporadic at first so no immediate panic as to what would possibly be causing this issue.
For the past week and a half, it's been near consistent. Again, mainly after reversing out of a parking spot and then upon engaging 1st. 2nd was my prior option to forward movement but it too is feeling "blocked" out. I've found another quick shift into reverse, slight grinding, and then right back into 1st (all without releasing the clutch) will get me on my way. Again, certainly knew this wasn't "right" but as being a tax director there isn't a lot of free time on my part right now to start diagnosing.
Of course, panic finally set in on Friday while on my way to pick up my son from his school. No problems leaving work, 15 mile commute at speed with no problems and then get on a main feeder road in the suburb. While taking off on flat road from a stop, there was a very noticeable rubbing sound as if something was wrapped around the halfshaft or front wheel. It had been raining for most of the commute. Regardless, this noise was present while under forward movement for roughly 10 seconds. Mainly enough to cause the panic as I was needing to get my son picked up without delay. The noise went away on its own. There were several more stoplights and bumper to bumper traffic as I went the remaining 3 miles to his school. No more noise, nothing. I babied it home, roughly 5 miles, as wife was out of town and I didn't want to get stranded with my 4 year old son.
I did some quick visible checks. No visible puncture in the tranny case. No leaking fluid. Wheel has no play in it. (Steve replaced both front bearings roughly 5k ago) Subframe is tight to the body. Clutch pedal adjustment resulted in no clicks from the quadrant.
I started it up today in the garage. No noise at idle, no noise upon reversing or forward movement. I did experience a slight delay in getting the shifter into 1st. I'll most likely take it out for another quick spin tomorrow to check for more issues before possibly getting stranded during the daily commute...
This thing has been babied for its entire life. Started out new in the family and I purchased it from the parents so I know its entire history. Thoughts on possible causes? Sucks not much of the likely issues can be diagnosed without taking it apart again. Sure wasn't much fun last time and I know Steve isn't looking forward to doing it again! Thanks in advance.
RStalveyARFF
too many shos
Georgetown, MA
With the tranny in neutral, place the clutch to the floor with the tip of your toes and allow it to snap back up. See if that changes anything. If not, time for a fluid change!
fricker66
Short update:
I popped the clutch a few times as mentioned above. The commute to work went by with no issues. It was certainly put to the test as traffic was backed up for 5 miles with nothing but stop n go. Once it cleared, I did a few WOT runs up to 5th and everything seemed normal. Guess we'll see what the drive home tonight brings...
I did some searches and found several recent postings that mention similar problems. Several suggested ideas were replacing a stretched clutch cable and/or quadrant. These posts made me realize I forgot to mention that for many months prior to the initial flare up, the clutch cable would groan quite loudly when pushed down or letting the pedal back up. I'm wondering if the friction stretched the cable beyond normal use?... Any more thoughts or advice? Also, the MTX is filled with Mobil 1 ATF so I know it's a proper fluid.
Howdy_Doody
Chesterfield, MO
If it's easy going into reverse, it doesn't sound like a clutch problem...that's usually the hardest gear to engage with a clutch that's not releasing properly. I'd keep looking at the tranny linkage or fluid level.
I sympathize with your daily driver status. I drive my 94 30+ miles per day, every day of the week. And planning a 1000+ mile trip this summer up to Michigan.
