SuperG
Cleaning the IAB proved to be worth it since quite a bit of carbon came out. Here is what happened after replacing the clean IAB:
1) The little plastic plunger is cracked, but I cannot tell if that is a problem.
2) I could not see any ports as described in the Shotimes instructions, except of course the 2 main ports. I was expecting a port to reveal itself when I moved the plunger, but did not see anything.
3) I reset the EEC. The engine ran a little better...this morning I PLUGGED in the ISC sensor and the car ran MUCH better.
4) The car runs so much better, that the IDLE is so high that I have to really hold the brake to prevent an accidental launch into cross traffic!
What on earth is happening? Should I buy a new IAB due to the cracked plunger? Should I manually lower the idle?
In addition, there was sand (or some kind of coarse material) in the IAB...also, is it ok to squirt C&C into the exposed ports facing the TB with the IAB off? I am concerned about the gunk sliding into the TB and manifold...
