cleaning carbon deposit
quikSHOilver
Yamahaized
Indy
I got 77k mile 3.2 and it look great inside as you can see...Utf 8BSU1HMDIwMjctMjAxMTA1MjQtMTUwMS5qcGc
Done swapped 3.0 intake cams and cleaned out the spark plug wells,
only thing I am debating whether it would not hurt to use berryman B12 to clean out the carbon deposit in intake tract on heads, supposedly I fill up the tract and let it soak. Will it seeps past valve seat into cylinder/ring land or thru valve stem if have engine turn over upside down to let residues drain out. Would you guys do it?
itwonder
VA
I filled up the ports on mine and let it soak. Afterwards, I blew out the cylinders with compressed air and cleaned out the oil pan.
