Check engine light on
MEY8126
IN
Pulled code p2195 from car = O2 sensor signal stuck lean bank 1 sensor 1 . Anybody know how to identify which sensor this is, apparently there are 4 O2 sensors .
bank 1 is the right or rear bank. sensor 1 is the one closest to the engine.
SHOrod
Torrie Tuned
Cedar Rapids, IA
To clarify on what's mentioned above, the engine in your SHO will have bank 1 near the firewall since the engine is transversely mounted. For each bank, there will be 1 oxygen sensor before the catalytic converter (sensor 1) and a second sensor after the converter (sensor 2). This is so the OBD system can monitor the effectiveness of the catalytic converters.
-Rod
Scott13SHO
One thing to keep in mind is you might be having a issue with the capless fuel system on the car. I know my fiancée's Escape check engine light was coming on and reporting bad O2 sensors. I replaced them and still had the same problem. I come to find out that the valve failed in the Capless system and was sucking fuel into the system and ruined the Fuel Evaporation system. $500 bucks later it was fixed...
bill1
texas
Over filling them will cause the same thine filling the EVAP system with fuel.
