Silvapain
I installed a NESHO catless Y-pipe weekend before last, and ever since I've had a weird noise. It sounds like it could be either an exhaust leak or a rattling heat shield, but I can't tell for sure. It's only there when the car is idling in gear and about 2500-3500 RPMs; not between idle and 2500 and not above 3500 RPMs. I've taken the Y-pipe off and resealed it with Copper RTV twice at both the exhaust manifolds and at the flex pipe, and had absolutely no change in the noise. I used OE Ford exhaust gaskets at the flex pipe, and I'm currently using two gaskets there instead of one.
Anyone else had this problem?
