Car Won't Start
TURBO91SHO
Boost Hungry
I have a 1991 sho with a 3.2 swap and sometimes I can start the car over and over again, but sometimes it will just crank and will not start at all. It is weird. It could be running fine one day and the next day it just will not start. What could be happening? There is no check engine light. I have not pulled code because I do not know how. Any help would be appreciated. Thanks.
Ishodu
To learn how to pull codes look at the link in my sig. It could be fuel related or a cam sensor, do you ever hear gurgling from the fuel tank when this happens?
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Walmart sells a scanner for >$30. It will tell you the codes and comes with a handy book as well.
TURBO91SHO
Boost Hungry
There is no gurgling sound from the fuel tank. One of my friends has a scanner and he is going to help me pull the codes. Thanks.
shoteen95
isn't a teen :D
Dearborn Heights, MI
What does the gurgling mean again, cause i drove my dad's 93 for a while today while mine was getting a brake job, and i noticed that sometimes before cranking, i would hear what would most definately be described as a gurgling from the tank. It also idles a little weird, low at times..with a nice amount of sputtering and shaking..
Pump on it's way out, or maybe just a bad filter?
