car will run for half hour then dies
Esteban
englewood fl
I have a 91 sho with 180.000 miles on it it was runinnig good until last week the problem that i have is that run good then dies then half hour later star again about a year ago i change the water pump and the cps sensor I think is the water pump is leekin water into the cos sensor I need help please.
kevinspann
Don't take my advice.
Richmond VA
It sounds like there is water leaking onto the CPS, but we need you to actually look at it to verify that.
RonPorter
SHO Club of America
Lake Orion, MI
Just don't drive anywhere that's more than 15 minutes from home......
(Sorry, couldn't resist!!)
I dunno about the CPS/water deal. Still not convinced that it is a cause of CPS death.
Anyway, IMO it sounds like something heat-related in the electrical system. Wire break, bad connection at a connector, DIS not properly insulated, or ???
Others may have other thoughts.
sperold
Last to Know
I would get the dental mirror out and try to find that weep hole in the bottom of the water pump snout. Look for a track that water has been following - like a shiney little river.
I am not sure that it kills the CPS, after all it is a sealed unit, but it sure confuses it.
TwistedMunky
yakima,washington
My 90 had no water leak, but the cps was dead. Are old 93 had a water leak and did just like yours does. It was the gasket on the back of the pump. Time to do a 60k.
bmytych
