car starting problem
Revere sho
Revere MA.
ya when i woke up this morning. my car started really quick and then shut down. the check engine light came on and then it wouldnt start back up at all. i tried a couple of times and then it did start but it ran like crap and then shut back down. i waited like 3 min and then tried it again and it did start finally and when i drove it to work and shut it off it did the exact same thing. what do you guys think it is?
SHO#7
Cincinnati
I would check you codes. My 93 just did the same thing. It started, ran poor, then shut off. It would crank like crazy, and I had a tach signal.
I scanned it, got the pip signal erratic code. Now it is time to do a crank sensor. And it is my own fault. To save a buck I did not do it, a few thousand miles ago when I did the 120k. I did the pump and timing belt, but no CPS. Shame on me.
I wish I did not love this thing.
Redline
Fire It Up
Sandpoint
Similar thing happened to me the other day. It cranked over fine but didn't want to start. After several tries it started but i had no reading on my RPMs and i had a check engine light. So I shut it down and then it REALLY didn't want to start. I would crank it over and it would **** and cough, and basically sounded totally messed up. It would almost start, but then die. Finally it started and ran ok so I shut it off and tried again. Same problems. I waited a few minutes and then it started fine and has had no problems since. Very weird.
