car runing hot
kendal_jones
tha sho off
manchester ct
my cars seems to be runing hot i also have a ect problem but the car is not overheating the temp says its normal and when i drive i can feel the hot engine heat inside the car.
Yamaha V6
SHO Enthusiast
Rhode Island
Is enough air getting through the condenser / radiator? Rad / coolant hose blockage?
SHOtimer
#2910
Santa Clarita, Ca
The fan does come on when you pull codes? If yes, then your problem is most likely a faulty ECT. Get a motorcraft one and replace it - it is the sensor that tells the computer to turn the fan on.
Doug
kendal_jones
tha sho off
manchester ct
i just replaced that sensor last weekend i did get a check engine light but it does not come on anymore but last time i pulled the codes i got a code 117 ECT indicated 254degF. Circuit grounded.
SHOtimer
#2910
Santa Clarita, Ca
Their have been cases of people getting faulty sensors from autozone or kragen....
Well, is the car actually overheating?
Doug
kendal_jones
tha sho off
manchester ct
i really can't tell i go by the temp gauge but the car does get hot when i drive. i can feel the heat from the engine inside the car also i did get that sensor from autozone.
SHOtimer
#2910
Santa Clarita, Ca
What do you mean you can feel it inside the car? Do you have the heater on, or the window down or what?
Doug
SHOtimer
#2910
Santa Clarita, Ca
Is the heater on? Engine heat does not commonly transfer itself into the cabin like that - even if it is overheating.
Doug
