Car not Starting
NoSHOAllGo
Bay Area, California
Engine wont turn over, but the battery is fine. At first I thought it was the starter, but the noise Im hearing is a buzzing/ticking noise repeatdley very fast.
Any idea what it could be? Thanks
1993MTXSHO
Its a Taurus...
Jersey
sounds like a dead battery, so if your battery is ok, id say check the grounds and the wires on the starter to make sure everything is tight and making a good connection. But be warned do NOT tighten the starter nuts to much or you will crack the solenoid open and then you really will need a new starter.
NoSHOAllGo
Maybe thats the ticking noise Im hearing then in sounds like it was in that area. Cause I was looking at the connections and everything was fine, no wires were stripped, everything bolted up, connections were all checked.
What should I do? That has to be the problem with it
