vortex2450
Buying Parts...
I'm still troubleshooting possibilities but here's the issue.
When accelerating anywhere over 1/2 throttle the car nosedives once it hits secondaries. The secondaries are audibly opening but the power just isn't getting put down to the wheels. If I try to gun it while past 4000 rpm the car just stumbles.
The clutch in this car is definitely old but there is no apparent slippage going on. Another issue I have is that the MAF is from a 93' Cobra, it is 73mm ( I believe) and uses the same internal sensor as the stock MAF. I've tried changing it out for 2 known working stock MAFs and both times the car refuses to even idle. There is no LPM either.
Voltage is good, oil pressure is good. I plan on pulling the spark plugs and checking them soon. Grounds are all good.
Still debating what exactly to go after.
-Josh
-Josh
