Car Lowering
lip
Rochester Hills, Michigan
I was thinking about lowering my car by heating up the springs and then pushing them together. Is that a good idea?
Thanks!
89' Black
117k
K&N Filter
Coneless
3" exhaust tips
TURBO II mufflers
Bosh Platinum +4 Spark Plugs
Filled up body lettering
SHO windshield decal
Krypton SHOoff headlight bulbs
RAZO shift ****
Petr Lipus
[email protected]
Shoman94
Maine
Thanks!
That would be like putting Festiva springs on there. You'll ruin the ride and probably other components.
'94 MTX Silver
Tokico Struts, Eibach Springs, Spmotorsports SubFrame Conn. 29mm ShoShop Rear sway bar, Shohop Cat back, Gutted box with K&N, '96 Brake Upgrade, White Face Guages.
whit
car in front of you winning
ok I am new to the sho sceen but on my 89 s10 blazer i broke springs all the time. on my 95 saturn .....well after bending spring and braking them i well.....took them out and i must say the stock sho rides too nice to mess with.
shoot
94shoboy
south shore, mass, usa
the best way to lower it is with an IPT coil over kit, they will give you your choice of spring rating so it will ride the way you want it to. you can also buy lowering springs, but they don't lower it that much. someone has fabricated a coil over kit to fit his SHO but its not suggested because the front main strut was not made to support the weight of the car, the IPT kit comes with special plates to support the weight. i have the kit, but its uninstalled for now. they pieces are of incredible quality and for the price, its the best you can possibly expect.
Shoman594
Moderator
Lockport, IL
lip:
Thanks!
No this is dangerous..... It could distort the metal there for ruining the springs, and also making them weak
olympic
Saskatchewan, Canada
Heating the springs will cause them to lose their "temper". So they'll lose their ability to support weight and be more prone to breaking. Cutting the springs is a little better but you still sacrafice ride quality and suspension travel. The real solution is aftermarket lowering springs or the coilovers mentioned above.
1/4MILESHO
NJ
Hey sombody was talken about coil overs before where can i purcahse them i love being able to adjust the ride hight of my sho
thanks nick
RJ-92
Crappy NYS
From Shawn P. @ Ipt automotive. Its on our sponsors boards. Shawn is a great guy who frequents this board, he is co-owner of ipt and designed and developed the kit. It is Bad A$$.
Just don't use the "contacting forum members" forum to contact him. He don't like it...
Right Shawn?! wink
