Edward Birdsall
Dear Potential Buyer:
I am selling my clean 1994 SHO to help fund another car project. It has power everything, including automatic sunroof! I purchased this car from a H.S. friend with the hopes of restoring it to its full glory and adding it to my growing permanent car collection. This is a very fun, fast, reliable, safe, and comfortable car to drive. It is also my daily driver. It is also becoming quite rare to own. It will be truly missed. Over $8k invested in restoration. Asking $1,500 or best offer. Thanks, Edward
I can be reached by cell number at (914) 582-4035 for more details.
All Restorations Professionally Installed.
* Rebuilt transmission with torque converter and installation completed at 161,880 miles, (but not shifting correctly, yet)
* Installed new computer.
* Replaced all brake lines, courtesy of ShoNut for supplying the parts
* Installed premium brake pads and rotors, front and rear.
* Synthetic oil change and filter every 3k miles or every season (which ever comes 1st)
* Flushed radiator system
* New OEM Windshield and Driver & Passenger Side Rear Glass Quarter Panels
* New Front & Rear Engine Mounts
* New OEM Power Antenna
* New Spark Plugs and Ignition Wires
* New Custom Exhaust Pipes, Mufflers & OEM Tips (small exhaust leak developed from weld)
* New Front Manifold Gasket
* New OEM Climate Control Instrument Cluster
* New Lloyd Embroidered Floor Mats
* New OEM Horn Assembly
* New Alternator
* New Interstate Battery
* New Driver & Passenger Automatic Door Lock Actuators
* New Fuel Filter
* New Fog Lamp Bulbs
* New 3M Window Tint
* New Power Steering Pump & Reservoir
* New Alternator
* New Serpentine Belt
Here are a few other fun facts from original owner:*
* Ported heads.
* 3.0L cam installed.
* Stock exhaust replaced & cat deleted. (Weld leak on down pipe)
* K&N panel filter.
* 70 mm MAF
Suspension/component modifications:
* 96 Brake upgrade
* FPS Subframe connectors
* FPS Aluminum subframe bushings
* Koni inserts / Eibach springs
* Front strut bar
* Kenwood subwoofer amp + 10” Bazooka
* Alpine head unit
Repair (To Do List):
* Although the rebuilt transmission shifts through all gears OK. At times, the transmission will shift out of 1st gear into 2nd gear with a hard bump. In addition, when you want to accelerate hard to pass a vehicle on the highway, the transmission will release the top gear and rev, then bang hard into the lower gear if not careful. When using the overdrive trigger on the shifter, sometimes the front end shakes from the torque. Lately, the transmission has been slipping at times when cold, although the reservoir is full to spec. I'm not a mechanic, but I have been around old cars all my life. I feel the transmission can use another rebuild and a different torque converter. If it were me, I would purchase a crate rebuild with matching torque converter and send the car's core to the supplier. They are cheap to buy now, about $1,200. I found one here: https://spprecision.com/products/ax...MI987flcTw4AIVCz0MCh0jOgCOEAkYAyABEgK5lfD_BwE
* The upper serpentine belt pulley squeaks at times. They are hard to find. I would remove and soak in oil for a week and re-install.
* All 4 car tires need replacing. The are safe to drive on dry roads, but not wet or snow.
* The back of the headliner at the rear glass is beginning to tear. Looks good everywhere else inside.
* The rear defroster stopped working this past winter. About the same time the rear glass was tinted prior.
* Rust has started to peek out of the drive side rear quarter panel fender lip and around the rear glass trim.
* The exhaust down pipe will need to be replaced or repaired to fix leak noise.
* The foot emergency brake does not work. It had not worked when purchased.
* The car sometimes has difficulties starting hot (after driven).
* Water/moisture is getting into the trunk.
* A/C needs a recharge.
These are the only remaining issues I know.
* New Alternator
* New Fuel Filter
* New Alternator
* Ported heads.
* K&N panel filter.
* 70 mm MAF
* 96 Brake upgrade
* Front strut bar
* Alpine head unit
