Firstly the car is a 95 ATX with 91K-mi.
I did the 96+ upgrade today, and changed the fuel filter. The old filter must have been the original one because it was rusted and blended in perfectly with the rest of the under-body rust. Took me two passes around the car before I finally found it. Definitely one of my problems. When I poured the fuel out backwards (poured out the inlet side) I got all kinds of nice brown rust come out as well.
But now I have a new issue. It seems like the FPR is stuck partially open. I can start the car, and drive it up to about 1500-2000 rpms before it starts falling flat. This is definitely a fuel related issue, not knock or a miss. The car idles good, doesn't miss, I get no pops or bucks or jerks when trying to accel, it just goes flat.
I turned the car off and let it set for 10 mins. I then hooked up my fuel pressure gauge and had about 20-psi at the schrader valve on the rail. When I start the car and let it idle I have about 30-psi without fluctuation. By just revving the engine without load the fuel pressure will drop down to 20-psi or lower and then come back up once it's at idle. I tried knocking the fuel pressure regulator with the handle of a screwdriver but it didn't do anything. If I pull the vacuum line on the fuel pressure regulator the needle comes up quickly to around 35-38-psi and stays there. Engine idle also smoothed out nicely as a side note. From what I read in other threads that is a good pressure for the pump to push, and it holding 20-psi when off means it's not a bad check valve in the pump (I hope!).
SO, the big question is, Is the FPR my issue? Or should I check and look at other things too?
As always, any help is appreciated. Eventually I'll just do like everyone else on here and buy a second SHO. That way I always have one to drive and one to wrench on.
