Car dies --- Cranks but will not turn
joshwise2003 said:
yes i checked the shrader valve and the fuel just dribbles out but i can hear the fuel pump kick on when i turn the key.. uhg :confused:
It should spray out aggressively. Unfortunately, a pump can sound normal but fail to provide fuel in volume under pressure.
Hopefully, you have already checked/replaced your fuel filter.
Jaz2099
Rockford, IL
joshwise2003 said:
yes i checked the shrader valve and the fuel just dribbles out but i can hear the fuel pump kick on when i turn the key.. uhg :confused:[/QUOTE
Was the engine running while checkiing it?
joshwise2003
easthampton
nope, but the funny thing is when i leave it overnight now i go to start it, it hesitates at first but then turns on and runs fine, i shut it off and go to restart....nothing :frown:
Jason Bowles
Curious Kid
Lacey, WA
TRY THE IDLE AIR CONTROL or IDLE AIR BYPASS valve. I didn't have time to read all the messages but I thought I drop a line and see if I could be the savior. I had the same problem and it turned out to the IAC/IAB. It's about $100.00. It's just opposite the throttle body.
