jimbobzsho
I'm getting a ticking sound from filter and I removed it and I cant blow air through it can this be cleaned or just replace it would that be why I'm running so bad.
Wish I would have read this before I posted my own question. So, does anybody have a part number for the valve?Originally posted by AutoXSHO:
What that is is the canister purge valve, which opens up and lets the motor suck the gasoline stored in the charcoal canister into the motor to be burned.
Worst case, the valve will stick closed and you'll start smelling gas from the saturated charcoal canister.
Originally posted by philw349:
You can get one at Autozone, its like $24 there and if you tell them what it is and for what model they will give you the right one. At least they did for me.![]()
Originally posted by FordLover:
What? you mean you told them the car you have and they actually gave you the correct part? I went to autozone and tried to buy a front motor mount for my car, they kept trying to sell me the mount for an ATX. I even had them check the 89 SHO model and it came up as the same ATX mount. What a pain!!
-Martin
