cam swap to 3.2 sho
89SHO X2
Wa
is it really worth it to swap cams? what is the difference between the 2. and what do you gain?
hawkeye18
Sorta cares
Norfolk, VA
Open up the valve covers... look at the cams. If all four say KOB on them, then they're ATX cams. If they say KOA on them, they're MTX cams. I think it's the intake cams that'll say KOA if they've been done; I don't think there's a difference on the exhaust cams.
byersmith
SHOpwrdMR2?
Toledo,Ohio
Well, while considering a cam swap you should think about your budget. If you want a little bit more pep ( due to the 3.0's lift) use the stock 3.0 Intake cams. If you want to spend some money, get some aftermarket ones check out SHONUT.
Byersmith
89SHO X2
Wa
what all you need to do to swap them minimal. and about how long? i ve just replaced the major components on the front of the engine.
hawkeye18
Sorta cares
Norfolk, VA
The cams are a lot harder than they might seem at first; it requires removal of the timing belt (and all that entails), all the cam caps, the cam chains (on the other end) and cam tensioner, and then finally the cams themselves. There is a good write-up on most of it at SHOPP.
byersmith
SHOpwrdMR2?
Toledo,Ohio
Just Depends on how mechanically inclined you are. While you have the Intake off, Might as well do a FULL 60k IMO. So more time is involved but youll be WAY more comfortable that your cam swap/hours are secure and your not gonna have to tear it apart anytime soon. like i said IMO lol
Byersmith
89SHO X2
Wa
not a nessary thing to do right now or even at all. i bought a cold air intake sys. with 80mm maf and k&n. also a modded computer(adjusts shift point and adds power). for $125.
89SHO X2
Wa
what is a KLZE? it doesnt have a plug in chip into it it has a ribbon cable connected there coming from the inside. dont know how that works. my 89 comp i pluged a jet chip into.
Racer X
SHO Pilot, Retired
Connecticut
Cam replacement isn't that hard, don't scare the kid.
Oh, and no such thing as a KOB exhaust cam; they're all KOA. Only the intake cams were different, and as such, are the only KOB cams in a SHO V6.
anmetcalf
Indiana
I have a 3.2 and I just looked at mine and they say KOA. So are they out of a 3.0 for sure.
313tiger
