Buh bye amps
OzzmanNT
Dinwiddie, VA
Removed: AMPs, bracket for amps, bracket for relay or wutever, foam around speakers (what the **** is that all about?), and that black cardboard
Finally got rid of the cluster in the trunk, I just couldn't stand the sight of it. Moved the Cluster of wires in the trunk behind the carpeting, removed the bracket, then the AMPs. They are useless to me, not worth the extra cluter/weight, plus the amp in the deck does good enough.
Anyone removing the AMPs remember that there are 2 screws at the top of the bracket, under the rear deck. Also if you didn't buy the wiring harness that included the line level converter (i think that is it), then just remove this crap. It's now dead weight.
Next is to take carpet from a taurus in the junkyard and mold it to fit the back of the seat and under the rear deck.
I think with some carpet on the back of the seat. It'll look a lot cleaner thumb
Now if I could only do some folding seats mmm
http://www.ozzmannt.com/images/v6/DSC00457s.jpg
http://www.ozzmannt.com/images/v6/DSC00465.jpg
and for those of you that don't know, the 98's TC is busted and the 91 drives again.
Anyone know if it is all that bad to lay the ABS module that sits beside the airbox on it's side? Trying to get a nice clean look here, and with the airbox gone, it looks out of place.
