Broken DIS module...what could have cause it??
SHOman247
michigan
ok i was driving home to day and my sho quit....so i poped the hood and seen that that the rear connector of the DIS module was broken and the connector sperated from the DIS...what could have cause it to break...oh and the rear connector touches the upper part of the motor mount on the shock tower....oh and bye the way I'm SHOman247 but i won't let me use it...so i just got her a week ago...also should i take her to a dealer for the sfb recall?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
FOR SHO:
Maybe some bad motor mounts?
that or Subframe Bushings are the only things that would cause it. And since you said it hits the support, it could be either.
SuperHO
Mental Patient
St. Joe, MI
Bet on the subframe bushings. I've had bad motor mounts for quite some time, but until I got the tranny replaced and the subframe bushings fell out in pieces, I never had that problem. So I yanked the torque limiter and bracket off till I got new bushings.
Silver 92
3.2 w/ 3.0 intake cams
gutted cats
gutted airbox
Dynomax exhaust
very, very sick headbang
Nook
SLC
Havng JUST broken mine while replacing a rack, it appers that as little as a 3/4" drop will cause that rear DIS section to hit the TQ limiter mounting thingy.
N
bmytych
