Brake question.....
cougarman
Fenton, Mi
...so I come home from work with lot's of brakes, park car. Get up to go to work and have a really soft pedal, no apparent leaks, fluid up, but pedal goes almost to floor. Any ideas?? 92 mtx.:biggrin:
Shuey
MidWest
Worse case scenerio, brake master cylinder is bad. You should really follow up on this.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
X2 with the above mentioned ideas. Bad master cylinder, or air in the system will cause you to have a really soft pedal.
