brake question (again)
way2evil
ny
So as I become more acquainted with my car I have noticed something odd. My front wheels have virutally no brake dust after 3 weeks without a wash. The back passenger wheel is black (literally black), and the back driver wheel has a slight dusting. Now every car I have ever owned has always produced more brake dust up front due to the brake bias (I assume) except this car. Could this brake dust be evidence that my front brakes are not working the way they should and my rear brakes have to work harder to stop the car?
SHOrod
Torrie Tuned
Cedar Rapids, IA
Yeah, that doesn't seem right. Does the car seem to brake well, or do the brakes seem weak and cause a bit of a pull under braking?
My car has the sport package and the front brakes definitely show more dusting than the rears.
-Rod
LJRuddy
Pop lock n drop
Poaceae fields
Is it possible that the front and rear pads are made up of different compounds for some odd reason?
way2evil
ny
-Rod
The car brakes okay, and that is just an okay, not good, not great. It does pull a tad to the right under moderate braking. When I was testing the brakes I could not get them to lock at 40, and they barely locked at all from 60-0.
LJRuddy
Pop lock n drop
Poaceae fields
My advice would be to wait until you have the same amount of brake dust built up and then take it to the dealer. That way, you can actually show them what is going on rather than them test driving it and finding nothing wrong.
wchain
Ecoboost
USA
This is/was a known issue from the Five Hundreds and Freestyles, where the rear pads were actually wearing out BEFORE the front pads, and putting out more dust than the fronts.
way2evil
ny
What was the fix?
way2evil
ny
I took a look at the brakes again today and noticed the back rotors are very uneven and ridged while the front rotors are smooth like glass. What is going on here?
edit: First pic is the rear, second pic is the front.
itguy08
Central PA
It's the way Ford programs their Electronic Brake Distribution. Under light braking the rears do a bunch of the work as it makes it easier to control steering. Nail the brakes and they all work like a traditional system. I believe it's the same way in the Taurus.
Check this thread:
http://www.fordflex.net/forums/viewtopic.php?f=20&t=2033
Look at the post by Waldo - he's a Ford engineer and he has some insight into how Ford has it programmed.
I wonder if Performance Pack SHO's have "regular" programming and the rest of us get the EBD programming.
SHOsc
South Carolina
Thanks for the info ITguy!
I have 22k on my SHO and the rear breaks are noticeably more grooved up than the front. I would consider myself a "light" breaker, so this makes sense.
itguy08
Central PA
No problem - glad to help. I'm a light breaker as well since I drove stick you learned to let off the gas early so you didn't have to do the foot shuffle. As well as the art of downshifting going down a hill and letting the transmission and engine do the work.
I do throw a hard brake in every once for good measure. :)
way2evil
ny
They are replacing my rear pads and brackets. They are also resurfacing the rotors.
Can anyone pull up TSB 10-07-02? That is what they used for the brake issue.
typhoon5000
Ferd Enganear
Shelby, MI
TSB 10-7-2
Applies to: 2010 Taurus, 2009-2010 MKS, 2009-2010 Flex & 2010 MKT
ISSUE
Some 2009-2010 Flex, MKS and 2010 Taurus and
MKT built on or before 12/14/2009 may exhibit rear
brake drag and/or off-brake cyclic noise. The noise
may be caused by pad to piston misalignment or
corrosion on the brake caliper bracket.
The fix is, as you mentioned, replacing the pads, caliper brackets and bracket bolts with a revised design.
way2evil
ny
I ended up buying a sub to motorcraft. Here is the TSB. And I now have access to all Ford TSBs so PM me if you need any looked up.
gregoire
nashville, TN
What was the fix?
The fix was a letter from Ford explaining the rear pads were stored in an imperfect environment. Premature wear could be expected in which case the letter provided coverage for all costs incurred to all Ford dealers.
harder99
Delaware
Wish I had seen this TSB earlier (my car date applies). My SHO has 26k on it, and the back right brakes were metal to metal a few days ago. As I needed a car, I quickly ordered parts and replaced the rotors and pads that day, thinking this would not be covered under warranty. When I got to the left side the brakes were barely worn. It appears the right side was hanging up ... a symptom of the TSB. I replaced the pads and rotors on both side and then saw this TSB shortly after finishing. I plan on requesting the dealer perform the TSB, as the bracket issue may still exist. Out ~$200 though.
Showgun
Canuck SHO
Cambridge, Ontario
Ask Ford for money you spent. All you should need is the receipt.
G/L
lowc
aka vapah lock
Quincy, massachusettes
hey came across this today
FORD: 2010 Taurus
2009-2010 Flex
LINCOLN: 2009-2010 MKS
2010 MKT
This article supersedes TSB 09-26-10 to add a production fix date.
ISSUE:
Some 2009-2010 Flex, MKS and 2010 Taurus and MKT built on or before 12/14/2009 may exhibit rear brake drag and/or off-brake cyclic noise. The noise may be caused by pad to piston misalignment or corrosion on the brake caliper bracket.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Remove the rear wheels and tires per Workshop Manual (WSM), Section 204-04.
Remove the rear brake pads as per WSM, Section 206-00. The notch in the caliper piston should be aligned with the pin on the backside of the inboard brake pad. (Figure 1)
Figure 1 - Article 10-7-2
Replace the caliper anchor bracket and anchor bracket bolts.
Ensure the piston slots are aligned per WSM, Section 206-00.
The new caliper anchor brackets should have a small amount of grease under the brake pad spring clips.
Grease should not be applied to the surface of the spring clips or come into contact with the pads.
Install new brake pads per WSM, Section 206-00.
Install the rear wheels and tires WSM, Section 204-04.
PART NUMBER PART NAME
8A8Z-2B511-A Bracket Plate Asy
8A8Z-2200-A Rear Brake Pads
W710681-S439 Bolt (2 Req)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
100702A 2009-2010 Flex, 2010 MKT: Replace The Rear Brake Pads, And Caliper Anchor Bracket (Do Not Use With Any Other Labor Operations) 0.8 Hr.
100702A 2009-2010 MKS, 2010 Taurus: Replace The Rear Brake Pads, And Caliper Anchor Bracket (Do Not Use With Any Other Labor Operations) 0.8 Hr.
DEALER CODING
