Bov not blowing?
Sho.h0e
I just did my both valve cover gaskets, and now it seems like the bov aren’t blowing off. Turbos are spooling and Everything is plugged in correctly and it seems like all the hoses are correct and tight. It seems if I take off the hose from the front BOV it will blow off but otherwise it doesn’t seem like it’s fully blowing off at once almost like it’s just blowing something else. Has anyone else had this issue?
FREAK_SHO
Wisconsin
Hopefully it's not cheating on you, it happens...
Sho.h0e
Figured it out!. The BOV to air pipe hoses were split at the spring clamp. For the time being I just capped off the air pipe (like most people do to let the BOVs sing) drove it and sure enough now they bovs are back to normal.
shootinirons
