doclees
Hi all. I am new to posting but have followed this forum for a few months. Thanks for all the help. Special thanks to New England SHO specs.
I can not find this problem searching the old threads. If it is there please point me to it.
89 mtx
Problem 1. Fresh 60k at 150k. Idles at about 1800 in neutral with clutch out. Rythmicly bounces between 800 and 1500 with clutch in. I have reset idle with no change. This problem was not present prior to the 60k but I only ran it for a total of 20 min from when I purchased it to the time I took it apart.
I did not decarbon the manifold - just the ports on the head per 60k video
Work done - valve shims, timing chains and tensioners (with cams in), adjust timing belt tension, new valve cover, plug well and intake gaskets, new plugs, changed all fulids, new hood lifts, fix tail light gaskets, repaired leather/cloth seats, recover gear shift ****. I also degreased the engine, tranny and steering. Behind the engine at the #1 cylinder I found a single wire connector separated with one end broken off. I ASSUMED they were ment to go together so I made it so.
Any clues?
89 mtx
Any clues?
