bolt size
D
WOONSOCKET,RI,USA
would any one happen to the bolt sizes on my oil pan{93 atx}.and also how big of a job is it to change the oil pan gasket?
i've been seeing alot of 92 thru 95 sho's in the woonsocket area just wondering if its any one from here.thanks for the help...
<small>[ March 26, 2002, 06:47 AM: Message edited by: D ]</small>
I just finished that job last week. Here is the topic and some pictures. http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=17;t=001375
The oil pan bolt and 4 nuts are all 12mm but you must remove the Y-pipe and starter to be able to access the bolts and remove the pan. You will need a good 9" of extenxions and a U-joint to reach some of the bolts. You will also need a deep 15mm socket to get the manifold nuts and one of the starter nuts and a deep 13mm socket to get another of the starter's bolts.
<small>[ March 26, 2002, 10:46 AM: Message edited by: sdpatt ]</small>
