bogging
raff18
frosty95mtx
ontario canada
well my car bogs if get into it at about 2500rpm then is fine after 4500 but only if i get on it like at wot
full full 60k done runs like a dream
maff is clean as a wissel spotless
cps and crank sensors changed
hawkeye18
Sorta cares
Norfolk, VA
Can you explain what "clean as a wissel" means? :rofl:
anyway, even though a MAF is clean as... whatever, it can still be bad. If the electronics fry or the wire changes resistance for whatever reason, it will still give bad readings.
Vnuk1
Mr. Mayhem
Minnesota
Yeah ask me how I know...:salute:
goalieman59
Learning Slowly
OFallon, IL
nope DIS is attached to intake tube near the power steering reservoir, and the tank sensor is on the back of the engine near the firewall, same side as the DIS. It is a black round sensor with two screws holding it in.
raff18
frosty95mtx
ontario canada
well just an update it seems to do it worse when the car is cold like i run the car for five mins let her warm up from not being drive for atleast 6 hrs and give her the gas and she slow as **** till 4000rpm then its like a hole new car and VROOOOMMMMM it take off like a rocket
raff18
frosty95mtx
ontario canada
nah if u free rev it like i mean u got the hood up and grab the throttle and rev it they open u can see em do it
sho2see
sho2see
Baltimore, MD
My car is doing the same thing like yours raff18.
I will try cleaning the maf first then see but keep us updated!
randy'sho
95 White MTX
High Point, NC
check your coil pack and make sure that all of your connections are clean and tight! had a similar issue a while back with a miss at low rpms and great up top....turned out that i had corrision that had eatin into one of my connections on my coil....swapped in a new "used" coil and walla!
