tery
Silvia survived the purge- summer car
Hi helpful folks,
So Bob has been sitting a lot getting repaired wheel wells and other things. The blower motor is doing this weird thing where it doesn't turn all the way off, even though the control panel says off. The roller wheel operates correctly from low to high, the vents and other buttons on the eatc work correctly, I think it did turn off once or twice while I was investigating, but most of the time it stays on low speed, again, even though it says its off. Has anyone had this type problem>>?? I've had the blower only on high issue and the resistor pack fixed that. Could this running on low and not turning off also be the blower motor resistor gone bad??
thanks in advance for your ideas
T
T
