Blacking Out Chrome Trim Question
CastorTroyN7
Green Bay, Wisconsin
For those who blacked out all of their exterior chrome trim pieces, what product (or products) did you use to do it?
I live in Wisconsin, so we deal with high heat & humidity, but also sub zero temperatures with snow and ice.
I like the look of it being blacked out, but don't want to use the wrong product that I have to redo or fix every few weeks.
Thanks for any input.
AlexS925
Metro Detroit Michigan
Check out these two threads of mine for ideas
Had my trim wrapped for about a year now, through a Michigan winter and washes and it's held up like new so far. Haven't had to mess with it at all. (yet). I'd say do it right the first time and you won't have to touch it.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Definitely use quality vinyl. Years ago I had used some CF vinyl from Auto Zone and a little after a year it started to flake off in some spots…as if it became dry and brittle.
When I did it over again a couple years ago it was with gloss black vinyl from Vvid Vinyl. It’s held up great, although the car doesn’t see snow or salt since early 2018. F4EB8602 414D 405F 9BBB E2E53C21174F6419BBA9 4663 45E0 A6F8 19E7B0BA5DE9793BD58E 3F03 48D5 8969 342C872CA332F4EB8602 414D 405F 9BBB E2E53C21174FACFEB45B 5D07 43D1 991E 8F7987CEC28E
skyshadow07
Oklahoma
3m is the way to go. I tried cheaper vinyl and plastidip, it all comes off. The 3M has held for 2 years now.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
3M 2080 from Fellers is the way to go and best pricing I found. Get the 2" strips for the doors with knifeless tape to get a good edge, and then get a few yards to do the trunk and grille. Take your time, watch a lot of YouTube videos, and you can do it yourself in a few hours with really good results on just a chrome delete.
Prep is your best friend and your enemy. Lots of rubbing alcohol, don't rough up the chrome, and don't use heat unless you have to.
Dieselcircuit
Detroit Metro area, MI
Just to add my two cents, I went the painting route and while it was good intially, long term I can't say im happy. I wanted it done professionally just to save the labor but every body shop near me didn't want to touch it, same with the few vinyl shops i checked with. I did all the work with the trim on the car, but I tried to do it right including all the tape and masking work and using a spray on over spray protector. I have a professional automotive paint store near me so I was able to get the supplies I needed.
I properly degreased and dewaxed the trim, used a adhesion promoter and a single stage urethane with a hardener. Initially it looked great but a year later I have chips near the edges here and there where the chrome meets the black plastic strip. I attribute this most likely to two things, one painting the trim on the car probably made this more difficult then needed when getting paint evenly to all the nooks and cranny's and two, plastic chrome is just a ****** painting surface no matter what and I trusted the adhesion promoter too much.
I imagine in the future I'll end up attempting this project again, but next time I will order an extra set of trim pieces/badges, sand or chemically strip the chrome off and then try the paint again. Once I have everything ready I'll find a bodyshop to swap everything out as I personally am too nervous to **** with taking trim on and off and lining up badges.
A whole lot of PITA to fix an oversight on Ford's part, they got it right with the Lincoln MK VII LSC's, I dont know why they forgot that lesson.
bmytych
