Bitter sweet STB install
zerg1024
NJ
i have had these for about a month now and havent had a chance to install them i just need to know what one is the front and what one is the rear?
SASHO91
Zoom Zoom
San Antonio,TX
just line up the bolt pattern..... :doh:
the front and rear are different.
if you have found one, you found the other...
zerg1024
NJ
no i mean the which one is the front there is a thick polished bar and one not so thick and not polished. also one is more bent then the other.
Jonny Cash
Good boy
Hollywood, FL
The thick polished one is the front. :oops:
Think about putting the dull bent one in the front. :nut:
Your hood wouldnt even come close to shutting...
zerg1024
NJ
i was also wondering if there is any way to get longer bolts for the STB that connect it to the plates?
The Ford strut mounts have longer bolts than most of the aftermarket ones I've seen. I put my stb on with the shorter bolts and didn't have any problems. I would have prefered a longer bolt though. I bet you could take the bolts off an old Ford mount and use them on an aftermarket piece.
zerg1024
NJ
i mean the bolts that are on the stb itself the ones with the hole in the top of it.
