Can a fully built N/A 3.2L SHO utilize a 75mm throttle body? I think the answer is yes.
I have been running some basic numbers on the SHO intake system to see whether there was consistency throughout the system. Does the system grow smaller in volume as the air moves closer to the cylinder, and does it maintain good velocity?
Here are the numbers:
Primary port area: 1.23” sq inches
Secondary port area: 1.48”
Individual Tube to Plenum 3.14”
Y Neck Dual Tubes 6.28”
Stock 65mmTB 4.9”
Stock 55mm MAF 3.7”
From the data above you will notice how the stock system starts small, peaks in size at the Y cross-section area, and then reduces again all the way to the valve. The stock TB does not equal the flow that the Y cross-section area demands, not to mention the MAF. As a result velocity reduces, and over-all peak power reduced. The stock system will have major restriction due to frictional pumping loses and reduced volume.
Most members on this forum when upgrading MAF choose the 80mm MAF. Some members have also upgraded to 69mm TB. The numbers with the new system.
69mm TB 5.77”
80mm MAF 7.76”
(The Center Bridge maybe worth 1.5” so 6.26” sq inches)
The new system gets very close to maintaining the same volume all the way to the Y area behind the throttle body, but could we do a little better? A 75mm TB would yield 6.819” sq inches and that would make the system nearly perfect all the way to the Y cross-section area.
CAI vs. Stock Filter Box
Many people on the forum believe the stock air box to be sufficient, but what if we could install a large box with bigger better numbers?
Numbers:
Stock Box Volume 141.45” cubic inches
Filter Surface Area 60” sq inches
CAI Box Volume 471.5” cubic inches
Filter Surface Area 170 sq inches
(Cone Filter)
Clearly while the stock system is not bad, it’s certainly not the best system available and best use of engine bay area. The CAI system described should yield less pressure drop, and reduce pumping losses to engine. Don’t know what a dyno will say, but the numbers look pretty good.
Anybody have anything to add or point out? Would larger filter area and bigger box yield more power? Can you ever go to big?
Stock 65mmTB 4.9”
Stock 55mm MAF 3.7”
69mm TB 5.77”
80mm MAF 7.76”
Numbers:
(Cone Filter)
