battery overcharging
Upstate NY
My 1990 SHO has a problem with overcharging the battery(boils it). It has worn out the one in the car so far and we picked up a new one today. We also removed the alternator and had it tested by a good electronics guy and he said the voltage regulator was fine.The battery idiot light also stays on. Has anyone veer had this problem and found a solution? The electronics guy said there may be a bad connection or a broken wire or something like that. Anybody have any ideas to throw around? Thanks in advance
Junkyarddog
somedude_001
Western NY
with the car running put volt meter on the battery terminals and give us the voltage. actually check voltage before you start and after it is running.
Upstate NY
before starting is 12.22 volts and while it is running is 15.20 volts. it is obvisouly overcharging but how and why? i wouldve had this on sooner but i had to wait for new accessory belts to come in before it got put back together.
Upstate NY
the connections to the alternator are clean and tight. I put dielectric grease on them. All the connectors appear to be in good condition.
rangerj
Brunswick, Ohio
Have the alternator checked again. If everything is connected properly then the only thing that can cause the excess charge is the regulator or a component in the alternator.
Upstate NY
we heard that the alternator may be getting a false reading that the battery is dead so it keeps pumping juice into it. Maybe a bad ground or broken wire? I thought that since the old battery was totally gone the alternator kept trying to pump it full of juice even thought it wouldnt hold a charge.
Upstate NY
we heard that the alternator may be getting a false reading that the battery is dead so it keeps pumping juice into it. Maybe a bad ground or broken wire? I thought that since the old battery was totally dead, the alternator kept trying to pump it full of juice even thought it wouldnt hold a charge.So it just kept boiling it
rangerj
Brunswick, Ohio
OK, so check all the positive and negative wires in the charging system, and the battery cables. Remove the light bulb from the under hood light and close all of the doors, glove box, etc. Put a volt meter on the battery and do a power draw test. Is something drawing power from the battery when everything is off? Is there a relay stuck somewhere, or a light switch that has stuck in the on position?
Upstate NY
The battery cables are totally crapped out. They need to be replaced badly. We are taking it to a mechanic and have them see if they can find out whats making it overcharge, and have them inspect it. Thanks for the help.
