bad tranny or not atx
glennb1980
massachusetts
rebuilt 30,000 miles ago by previous owner when tranny shifts from 1st to 2nd
at 2500 rpms or lower it bangs into 2nd gear if i accelerate so it shifts over 2500 rpms it shifts fine. could it be a sensor any info will help.
thanks
F-22 Raptor SHO
7015 feet above Sea Level
thanks
So if you pull down your street slowly and let it shift at 2500 it always bangs into gear, or only sometimes when you rapidly press the pedal then let off? Mine bangs into gear if I floor it, then let off before it shifts into second. 30k on the tranny fluid is close to the fluid change time.
glennb1980
massachusetts
if i let off the throttle right before it shifts it won't bang into 2nd. it only does it when i accelerate slow into 2nd 2500 rpms or under
ohfosho
ontario SHOwner
ontario, canada
pull your codes. and if you want to try replacing the sensors(VSS and another TSS?) first before the whole tranny
"SHO"time
shostopper
Detroit
thanks
ive had the same problem since i got my car.but ive drove it like that for about 2 years.and its still kicking
tedhontz
fort wayne Indiana
ok, i've heard a vss (variable speed sensor) and a TSS (transmission shift solenoid) and a lockout sensor, but not a transmission speed sensor. I'm having shift problem but yet all gears in tranny seem fine. When I punch the accelerator, the car refuses to kick down a gear for "passing gear". Any suggestions? Is there a sensor that I don't know about?
Sensors in the ATX:
TSS - Turbine Shaft Sensor. Measures rotational speed of input turbine shaft
VSS - Vehicle Speed Sensor
TOT - Tansmision Oil Temp
Sensor ON the ATX:
MLPS - Manual Lever Position Switch. Tells computer the position of the shift lever. Also has backup lamp and Neutral/Parl starter switch integrated
Solenoids:
EPC - Electronic Pressure Control
TCC - Torque Converter Clutch
SS1,2,3 (A,B,C) - Shift solenoids-
These are the official Ford designations.
ted: Go run your codes, ...
tedhontz
fort wayne Indiana
i've ran my codes. after installing a new vss i get o2 sensor codes but nothing about a transmission.
ALso, I went back to the beginning of this post and believe that i have stayed on topic with this post.
