Bad gas mileage!
caseywan
Chicago
A few weeks ago I was out driving and had some stupid kid in a cavalier messing around with me so I just had to show him up. I was going about 25 and down shifted to 1st (yeah, a little to low) and let it go up too high i think about to 9k. And then the engine was kinda sputtering and rpms were going up and down when I gave it any gas at all. So I pulled over in a parking lot, popped the hood to a take a look. Didn't see anything up top or anything leaking on the ground so I started it back up and it was just fine, no problems at all after that. But it does seem like I have been getting a lot worse gas mileage since then, like a little over 300 miles to a tank highway, and not even 300 street. I do have a chip and 80mm MAF that didn't really seem to affect my mileage for the first month or so that I had them.
Anybody have any idead what happened?
Blue-By-U
CT
I would start by running codes. You can do it yourself (search for a link) or you can take it to Autozone.
jaded93atx
Chicago
If it was stock then 20 miles to a gallon driving in Chicago traffic with accesories on isnt bad, add on a 80 maf and the occasional redline run and 20 miles a gallon seems exceptional. If youre concerned about mileage then drive 55 and steer clear of the smoke shows.
caseywan
Chicago
When I first pu on the 80mm MAF and chip, I got about the same gas mileage as I previously had, 375 or so highway and 325 street.
SHO-93-ATX
Smokey Bandit!?
Cheboygan, MI
damn, same prob with me, i got the same mods. but im only gettin 230 miles per tank in country atmophere, but i start the car like 12 times a day. and take a few short trips to lunch and to work coming from school. When i actully drive straight freeway, i get 300 per tank, and i driv e a 300 mile trip every other month. and thats just to the one location. i still havent figured it out.
Electricat
Decatur, IL
Lower MPG may just be due to the weather getting colder of late.....cold air is denser, which requires more fuel to get the proper A/F ratio, resulting in more fuel burned.
Also results in your car going faster, WOOHOO!!
crystizel
