haydenm315
The car is back on the road and running. I took it up to the station for air and ultra 94. It's running pretty good but has some tuning issues to be worked out. If there is a loss of torque, the weakness of my tempo has completely masked it and I don't know. I'm having some idleing issues at times. Sometimes it will idle fine in the 900's I think. Sometimes it will start to choke on itself and drop below 500 and the low oil pressure comes on. I think part may be my lack of high flow y pipe and new maf and intake. Gotta get that soon. I've also noticed that I'm losing my power brakes when the engine is ideling. When I tap the gas my brake pedal regains feeling. The car also backfires if I hit the gas too fast from a lopey idle. All in all it's driving nice and the valves sound good even though it was cold enough for me to lose feeling in my toes. I notice a whine that I'm sure is coming from the timing belt area. My thoughts are maybe I tightened the idler pullies too much or the belts are too tight. What kind of noise should a new timing belt make. I've left the upper cover off for monitoring purposes currently. That timing belt was out of package for a while and I ran the motor with it already before I ripped it all down for the second time.
