AWD not working
Joe Smith
ohio
2010 Sho. No codes, no wrench no nothing. Just FWD.. I figured if there was an issue, there would be an AWD disable light or code. I’m sure it’s probably a PTU FAILURE.. but I checked the AWD fuse and it was as solid.
Is theRe anything else in the fuse boxes t should check before paying for a diag? I’m wanting to sell this thing now and just throw some snow tires on the SRT 392 charger I got
Clutches in the RDU probably gave up.
If you suspect the PTU or the RDU, check the fluids.
No sounds at all at any point from either unit? Usually manifests as a whine or if gone far enough, a grind.
xFallenxCripplex
How many miles just curious because I have a 16 before winter got the rdu fluid changed I'm around 45k now
Sent from my Pixel 4 XL using Tapatalk
