Yeah so far haven’t had battery issues since.You seem to have investigated all the usual suspects.
No, wha happened was the infotainment screen, audio, AC, and some other things shut down. All I did was disconnect and reconnect the battery. Sprayed terminal protector on all the connections to the battery and the fuse box. The battery light did not come on but the car was throwing crazy codes and the safety belt and airbag light were on the fritz. If it keeps giving you issues I have no idea what it could be.I'm sorry for not paying attention but does your battery light come on on the dash at all?
I'm having major problems with my 2010
Changed alternator and brand spanking new battery.
Still batt light comes on and off and voltage seems to drop under heavy acceleration or something..
I'm following this one hopefully I will get some information I can use.
Good luck with yours
Dealership saying nothing wrong
Every time I take it in the darn battery light wont come on at all.
The problem is random but happens almost daily.
Now my alarm is going off every day at about 9am ..
Car I'd making me crazy.
I love it though
Also just paid it off and refuse to get a new car payment
The alarm is actually an easier repair/diagnosis.
Activate the panic alarm 4 times from the fob. Lock the car and wait for the alarm to sound. In the B.C.M. there are four alarm event PIDS that will tell you what caused the alarm to set.
Once you know what opening is causing the event you may be able to perform circuit diagnosis/inspections to isolate the fault. Like you could bypass the ajar switch in the door.
