Autozone heads
aryanramsey
Louisiana
I was looking for some 3.0 heads for my 95 ended up finding the pair of complete heads.My question was being that they are complete do they come with the camshafts?The bright individuals at autozone dont know. If anyone is interested the pair run $2200 without a core.
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
jelloslug said:
$2200!!!! That's insane. Why do you need heads?
I can add another $ 600 in top of what the head price is and i can get a rebulit angine from autozone.. suposeabiliy called new / remanufactured..:thumb:
endri
aryanramsey
Louisiana
endri
autozone charges 4700 for a rebuilt engine,so would it just be cheaper to buy a 3.2 from autozone and just buy different cams for it,thats why i was buying the heads.To swap on a new block
JoesSHO
Reality
Being down there, just get a hold of Doug Lewis- he'll set you up for waaaaaaay less than that with waaaaaaay better stuff!
aryanramsey
Louisiana
where would he be located? i called napa and the guy quoted me 1800 for a rebuild 3.2 shortblock but that cant be right,anyways i tried to call them back but now there not answering.Could they really be that cheap?
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Are you also paying someone to put the motor in, or are you doing it yourself? Not for nothing, but you can rebuild awhole 3.2 on your own for far less then that. If you've got the cash, and rather that route then thats just fine. Keep in mind that you can possibly rebuild a 3.2 with some bolt ons in that price range. Good luck!
1993MTXSHO
Its a Taurus...
Jersey
Yeah iv spend about 3k on my 3.3L build up:thumb:
Edit: that included oversized valves , a 3 angle valve job and bronze valve guides. Im sure you can get all that done for 1000 -1500 tops paying 2200 for those heads is ridiculous.
aryanramsey
Louisiana
im on limited resources no one has parts for these cars down here,no junkyards with these parts,so its really hard to find things down south.I tried at least 4 machine shops in and around my area and none of them will do a sho engine,so im pretty much stuck with buying a block and the heads.i would just get the work done on my engine but with the pos machine shops and coming to terms that its my daily driver, i dont have the cash right now so i was going to buy piece by piece.
aryanramsey
Louisiana
But if someone here had a 3.2 low mileage engine for sale that would be great,and i could just buy stuff for that engine without having to fix it first
Cocoa,Florida
ill sell you a set of reman heads with SHO SHOP stg 2 cams. with proper shims for $2100.00:biggrin:
jelloslug
Digital
Greenville, SC
You could just buy a running ATX car and have all the part you need. You can then sell what's left and recoup most of you money.
aryanramsey
Louisiana
But thats what you guys dont understand i had to drive hours out of the way to texas to find this one.
Endri_SHO
SE 300 , S 500
you're talking $ 4700 without your core, if you return them your old engine youll be knocking aound $ 1 grand, off.. so there you are $ 3700 plus if you know some body that work there can take out another 20% off so as i said up to $ 3000 taxes included.. right ?? :naughty: :thumb:
good luck though
endri
aryanramsey
Louisiana
yep,thats why i was seeing if maybe a chain of auto stores carried something cheaper.Ill keep looking and i appreciate everyones help
crystizel
