Auto-climate control problems
Soopacharged
Guest
Montreal
My climate control, manual or automatic, does not function at all. The display will light up but that's it. Is it a big job to fix? Let me know. shrug
SHOtimer
#2910
Santa Clarita, Ca
If the alternator isn't putting out enough charge (failing), then the whole cars electrical system is running on a lower voltage. That in turn doesn't give the EATC enough voltage to run it, yet enough to make it light up...or act strange.
Doug
projectSHO89
SHOless In St L
The symptoms manifested by the EATC due to a faulty electrical system are usually described as a flashing disply or the unit powers itself on/off.
Yours doesn't sound like that, but check the battery voltage anyway with the engine running to be certain.
Steve
SHOsupercharged
Downers Grove, Illinois
I took mine to the dealer and got it done for free...but it is not a big job, it did happen to me, but try that...if you do not have a warranty, try replacing the fuses...
