atx trans shifting a little hard
Revere sho
Revere MA.
i just wanted to ask just to make sure im not getting screwed. i just got my trans rebuilt in my 94 atx like 200 miles ago. its shifting a little hard when coming to a stop or letting off of the gas, basically coming out of gear. the guy said it was because of the codes that i have. i have 172 and 176 which i seen on SHOPP that those have to do with the 02 sensors. im asuming that i need new ones. he said with those 02 sensor problems that the car is getting wrong signals so thats why its shifting a little hard coming out of gear. is this right or is he bs
thanx corey.
Jonny Cash
Good boy
Hollywood, FL
Sup Corey.
If you are getting those codes I would change the O2's. If you change them, and nothing changes. There is a problem. I cant imagine the car shifting hard because of a bad O2 sensor. Then again I havent drove the car. Coming out of gear sounds kinda scary. Im not sure I know what you mean by that.
With these automatics.. If it doesent shift absolutley PERFECT. The tranny's shot more or less.
SHOtimer
#2910
Santa Clarita, Ca
The o2's have nothing to do with how your tranny works. However, I would replace them to save yourself the argument with your tranny guy. Then take it back and make him fix it. Put the Bosch sensors in.
Doug
FRDSHOGRL93X3
Shelton, CT
Might want to check your mtr mounts also? Had the a similiar prob w/my ATX shifting hard it was bad motor mounts.
SolidState
No Mo SHO
Toronto, Ontario, Canada
if they put a trans go into it, that will cause the symptoms you are describing...
I have been in windstars and SLOs that shift the same damn way....just a sh!tty transmission, any way oyu slice it....
