ATX shifting issues
JustinSane
SHO OFF
PA SHO Shop
fThe tranny will upshift threw the gears very quick rather then hold each gear like it should at WOT , then when you slow down it will down shift each gear rather abruptly, it also wont kick down into a passing gear when you mash it in high gear. its a 95 by the way, any ideas? possibly non related to this issue is the cruise control dont turn on, again maybe related and maybe not, please tell me what you all think.
sho'd
Git R' Done
ontario,canada
usually when the cruise isn't working, and your having said shifting problem, it usually points to the VSS. it's a cheap sensor, but a PITA to get at with tranny in the car. it can be tested with a digital multi meter, but you really have to have it out to get at it. my manual is in the garage, i will post the values for resistance on the multi test if your doing the work yourself, this is just a place to start. anyone else wanna chime in
JustinSane
SHO OFF
PA SHO Shop
yes please post the values and any other tips , most thankfull for the help.
1 other thing would this VSS also be playing havok with the ABS seems at slow speeds like in a parking lot i get alot of abs chatter in the pedal for no reason at all , i will just tough tthe pedal and get lots of feed back from the ABS. or is this another issue all together?
wood_e
The dude
Ames, IA
Probably a seperate issue - you can check your ABS for codes. Search the forum as there's instructions on how to do it.
JustinSane
SHO OFF
PA SHO Shop
can some one please post the method and values on checking a VSS? im taking mine out tonight and have a used one i would like to check.
socialdeviat
Ca
To test it you'll need a O-scope. Since it puts out a analog a/c signal.
But Im betting its safe to say its your VSS.
Ill make a write up on it since Im doing it tommorow.
socialdeviat
Ca
Im also betting you are having an issue getting the car above say... 3200rpm?
and for some reason my cars speedo dont work either... I thought this had a cable... Guess not.
JustinSane
SHO OFF
PA SHO Shop
The car reved fine and speedo worked fine, it only had upshifting and down shifting issues, we tested the VSS with a ohm meter and it was just about outa spec, The used one i had laying around was in spec and i installed it and now the cruise works and the shifting is fine, so all fixed. ;)
sho'd
Git R' Done
ontario,canada
glad that test worked out for you! good to hear you up and running again, i figured as much as the vss. pesky little sensors.
