hawkeye18
Sorta cares
My wife's has ATX has 202,000 miles on it from the factory. It still shifts well and won't need a rebuild for quite a while.
It's all in how you drive them.
I get my information from actual Jeep owners - we take them in on trade every day and virtually every one with over 100k has had the trans rebuilt.
My 93 failed at 120000 when, then rebuild and lasted 30000 more then rebuilt again and lasted 40000. (rebuilt by my father who is a ford master tech). I now just have a used trans and has been fine for the last 10000 miles. btw the first time it failed was when a rock made a hole in the pan, second time was the forward clutch piston, and thrid was the input shaft sheared.
Hole in the pan doesn't count due to "Force majeure". Forward clutch piston must have been the reused aluminum unit prone to failure and revised by Ford, 1994-95 models have the upgrade. The revised steel one would have solved that issue but not the sheared input shaft. If you kept the car after 3 transmission changes means you are truly a one percenter. You get a SHO patch! There are 4 major things to get done when rebuilding a ATX that I personally know of:
1.) Shift kit with the drill mod for more fluid flow to the sun gear setup.
2.) Fluid dam install. More sun gear **** as I understand it.
3.) High friction clutch packs. I think there is a extra disk that can be added to the pack from a Ford RWD transmission , the model in question presently escapes me. Someone chime in if they know what I'm talking about. My memory is shaky at best.
4.) Weld the Diff pin!!!
Above mods are not in any particular order. Get them all done if you go this route.... that is if your ever need it.
Don't forget the cooler!!
Are ATX trannys really that bad????
There is one clear advantage for the ATX......you can still get NEW parts for it!!!
With an MTX, your sol when it comes to gears, syncros, blocking rings, etc...
