Anyone Know of some good performance Mods, for the V-8's?
Bruticus
Ohio
I have a 96' SHO that has cost me a small fortune in recent repairs ($400.00 tune up, $155.00 coil, $200.00 tires and oil change). I really like the car, but come on this stuff is getting ridiculous. The car has 110k on it and I only paid $3500 for it in July. I used to race Mustangs, so I know about mechanics and power adders. What I need to know is what is available for the Yamaha V-8 cars? Any suggestions will help, I am no "Ricky Racer" kid who does street racing (anymore...lol). If you give a suggestion please tell me if the product has merit or if it's just something you heard about.
Thanks for any imput.
Bruticus
Mr Anonymous
Tire Wall
In the simplest terms, not much. Best bet is to start with the following, in this order:
1. Cam welding
2. Nitrous
Welcome to the forum!
You should also check out http://www.v8sho.com Lots of great information there about just about any mod anyone could ever think of for these cars.
laxmax327
philly
yea, i dont own the v8 variety, once thing even i know you must do. have the cams welded. all the upgrades in the world wont help once your sho goes sho-boom :salute: , but once you have that done, the engine will be pretty solid and can safely handle some abuse, then i would be 100% positive everything is perfect on it, then go for a nice big shot of the giggle juice :evilgrin:
Wess
Jarhead
MD
Your best bet for performance mods is to sell your SHO and go back to racing mustangs. :biggrin: Otherwise, enjoy!
Ian Macoomb
Ottawa, Ontario, Canada
Do whatever you can to avoid heatsoak. I coated my intake runners and surge tank with a ceramic coating similar to jet-hot. That made the car run a lot better in the hot summer months.
Doug Lewis's programmed X-Calibrator is worth getting.
Then I'd go with a UDP (not the SHO Shop pulleys which don't fit).
Then weight reduction and nitrous.
Exhaust and intake mods haven't made much of a difference. Do the exhaust for the sound only. And stay away from cone filters under the hood.
Bruticus
Ohio
So tell me how...
1. Cam welding
2. Nitrous
So tell me how one puts nitrous oxide into a tempermental 10:1 compression motor without welding the heads?
Thanks
Bruticus
Ohio
What type of pulleys ? I don't believe I am familiar with VDP pulleys. Are there any aftermarket exhaust kits? I think the motor breathes well being stock, but if there's a good system out there I am eager to hear about it.
Thanks
Mr Anonymous
Tire Wall
Thanks
Just get the jetting and fuel right. A 75 shot can be done on the V8 cars very easily and safely. We've done as much as a 125 shot with fatter injectors.
Don't know why you call the motor tempermental, once the cams are welded it's one of the toughest motors out there. Of course those who decide not to weld the cams are what keep us in business! :thumb:
Here is my current list 'o mods and other changes I have made to my car over the years.
Can't say that they all are effective or replicable but I likey.
Engine Performance
4" air duct with cone filter in the rearward sealed driver’s fenderwell
3rd cat gone
SHO Shop UDP
Resonator gone
Bullet mufflers
Gen 2 ATX cooler with high flow cooler lines
Amsoil ATX fluid & power steering fluid
Heat shield on the oil filter
Magnetic drain plug
Large size oil filter
Cams welded
Chain torque limiter
3.98 final drive ratio
100% brazed TC
Trans-Go kit and ’98 clutches
Jet Hot coated intake, exhaust manifolds and Y pipe
EGR and SAI deleted
Sealed crankcase intake hose with condensation can in line before PCV valve
Superchip Xcal 2 programmer
Suspension Upgrades
GM adjustable rear arms w/parallel braces
26mm rear sway bar with TPR bushings and end links
24mm front sway bar with TPR bushings
Adjustable front strut tower brace
Solid Aluminum Subframe Bushings
Sub Frame Connectors
225/55/16 Nitto 450 EP on ’99 OE rims
Kumho Victor Racers V700 on Borbet 7.5” X 16” rims
Eibach lowered front springs
Rear brake proportioning valve plugs
Electronic
VAL 1 w/remote display
Rubber shorty antenna
Profile 450w mono amp with 12" Sony woofer
SilverStar headlight bulbs w 100w harness
Rear turn signal/Brake light mod
Clear front sidemarkers converted to turning/backup lights
Rear fog light converted to a backup lamp
VAK with sealed Odyssey 26 lb battery in the trunk
Jacobs FR1500 Voltage regulator that maintains 14.4V when the alternator is disrupted by the VAK, switchable on/off
Hi Speed fan manual switch
Miscellaneous
Carbon Fiber/Fiberglass hood
3" under body side skirts
Yamaha badge on rear
Shaved trunk lock
LEDs in the Instrument Cluster
LEDs in the window switches
LEDs in the shifter
LEDs in the map lights
ArkanSHO
Arkansas
Thanks
Why do you have to weld the heads??
By the way, for the money, giggle juice is a good choice, over a 125 shot though and it certainly would be advisable to not only have Dougs tuning but also invest in some injectors along with the intake mod it will take to get them to fit and a fuel pump big enough to supply them. All this though and for the same money you could put a 'Stang into the 11's, but not sure you would get the same looks when you opened the hood.
Bruticus
Ohio
Where did you find a supercharger ?
I wasn't aware they made a specific supercharger for the V-8s. Could you tell me what boost level/price andmods needed to supercharge the engine.
Thanks,
ArkanSHO
Arkansas
Mine was a prototype produced by Geoff Knight of Boosthead.com in SOuth Miami. I was hooked up with him from Brad Hogue who also was trying to get SHOShop to put a supercharger on his without success. I personally think he had me go to Geoff to test him out. The system I got back was very prototype and I am still finishing it even today. Before I got back from Miami it shed a belt while Doug was driving it in Atlanta. I ended up redoing the the entire drive shaft, pulley's and mounting system for the blower itself. I have also redesigned the intake plumming and overpressure (blow-off) valve. A kit was designed based on my early prototype but to the best of my knowledge only one is mounted on a SHO but I do not know if it is running at this date. Originally the car had no mods other then a Vortech 12:1 FMU in the fuel line. Of course at that time I was only pushing 6 psi. Since them I have modified my fuel system by swapping to a 255lpm HiFlo/HiPress fuel pump and modified my intake to fit the 36# fuel injectors. None of that would have worked if Doug had not of made the ECU recognized the changes with the SCT Tuner. I added the PWR liquid to air intercooler that I had modified to fit in the engine bay as close to the TB to limit heat soak. The pump and reservior for the IC are in the trunk with the transmission cooler for a PowerStrokes transmission behind the lower grill as the liquids radiator. Thats about it for direct mods other then the mixture gauges and boost gauge on the A-piller.
Bruticus
Ohio
Thanks
Thanks for the info, since it is a prototype/experimental the cost must be high?
