Anyone know if this stereo will hook right up?
93redATX
SHOForum O.G.
WI
shrug
I think some here have said it does work though, simply plug & play. You could always buy it and if it doesn't work, re-sell it naughty
krupt89
Barrington RI
I dont see why it wouldnt seeing it came from a ford, although you never know w/ them, could be a completely different harness. If it is different you could just buy an adapter and hook it up like an aftermarket deck.
Goodluck thumb
ohioshodude
SHO'ld fogy
delaware, ohio
yep it will work as long as the jumper is in the back....... yep its there in the pictures. yep your set. thumb
buechine
Ontario, Canada
Thanks for the replies guys! I just want to verify that it will still run the amp and the factory sub. The jumper? Is that the small plastic connector in the unit or would I have to jump the amp in the car and run it like aftermarket.
Sorry I'm a little confussed,
Thanks Eric
jelloslug
Digital
Greenville, SC
It's the little plug that's the upper 6 pin connector. It's a preamp in-out loop and CD signal connection for the slave CD player. That unit should plug in and work fine, BUT if it's from a Contour it will have a green display, not a blue one like your car has now.
buechine
Ontario, Canada
Thanks, is there a way to change the color of the light if needed? Would you know if the redundant vol/tune switches will still work on the top of the dash?
Thanks again,
Eric
seth'sSHO
Selah, WA.
Yes you can replace the face. The bad is that bluish green faces are hard to find.
Yes, the redundant volume switch will also work.
Jelloslug, I take it you're no longer interested in my deck?
