anyone had any luck trying to redo soft EATC buttons that are already busted?
ohfosho
ontario SHOwner
ontario, canada
hey guys. im not interested in paying more than $70 for a whole nother used EATC unit just for aesthetic reasons. my broken-buttoned unit works perfectly fine! im curious if others have thought the same way in the past and had a good idea, or were succesfull in redoing their beaten up EATC buttons (not just superglue in the back of lightly cracked buttons, but like a new face on the front)...
JoesSHO
Reality
Sort of!
I put a piece of black electrical tape over mine, (worked back both above and below the buttons (Tucked around with a razorblade so it was only on the buttons themselves) and it actually looked pretty good (IMHO) and was totally functional. Best of all- no annoying light! :biggrin: Easy fix to see if you like it...
Here is a pic...
mlatten
Mons-taurus
Suffolk, NY
Nicely done, a fertive option. I'd like to ask, though, why the Ford symbol on your steering wheel is BLUE?!?!?! neither of my SHO's have that. It really cleans up the driver's side, so if you did it yourself, two thumbs WAY up. If not, then you have great foresight. In any case, nice job on both components.
Matt
JoesSHO
Reality
Thanks! It's one of those things I shouldn't have done because if my bags ever go off, I'll probably lose an eye... It is just an emblem off a '91 ****** (pried out of the steering wheel cover) clearcoated and epoxied onto my wheel. It's really stuck on, but I so like the look of the colored logos on the newer cars, I couldn't help resist addig it to mine. The older ****** badge is the only one I could find that was large enough to cover the logo on the wheel...
mlatten
Mons-taurus
Suffolk, NY
Excellent! I was afraid that you were involved in an accident and you got a new steering wheel because your air bag went off. Super news, since there are 3 older Escorts in my local bone yard. Thanks again, and nice work on both.
Matt
Rockledge
Pluggin' away
Connecticut
Hey that's not bad. Not bad at all. :thumb:
Certainly better than looking at a bunch of illuminated cracked buttons.
Rockledge
Pluggin' away
Connecticut
BTW, it's possible to modify some of the earlier units by adding later faceplates with upgraded buttons. The faceplates can come from a couple of select Ford models (I'm not sure about all the possible combinations myself). A year or two back I picked up a nice modified unit from Mike Gallion here on the forum:
Here's a post from a little while back from someone who did something similar:
GIL Shoemaker said:
FYI for y'all. I just completed a new style hardbutton EATC (the bubble button style) upgrade using a '92 SHO EATC as the guts. This upgrade required NO Electrical soldering. Here is how I did it:
Essentially, what you are going to do is swap just the face plates of the old (1992) and new ('96 and newer) units while retaining the circuit boards and lighting from the old unit. The LEDs are almost the same size, so the old unit's board fits into the new unit's faceplate.
1. Find new style EATC that has the proper color buttons on it. (I'll call this the new unit for the explanation.) (I have a '92, so I wanted the blue-green display, not the green-green display)
2. Find the proper EATC for your Gen 2 SHO or if you are brave use your existing one. (I'll call this the old unit this explanation.) I actually found a bone-yard '92 unit even though I was looking for a '93 or newer unit. I was going to do the resolder the faceplate thing, but couldn't find the proper donor unit for the electronic brains.
3. Disassemble the faceplate with buttons from the old unit - it will slip off from the faceplate circuit board revealing the LED display and switches. Also remove the main circuit board from the case. Do not break the ribbon cable that holds the faceplate circuit board to the main circuit board. Do not remove the LED display from the old unit's face plate circuit board.
4. All of the large buttons (ex. "Automatic", "Outside Temperature" and "Off" on the old unit use a single switch in the center of the back of the button, while all of the new units use a double switch with a switch at each end of back of the button. This is why everyone says that you just can't switch the faceplates. Disassemble the faceplate from the new unit. On the back of the new unit's faceplate near the plastic display window will be two plastic alignment nibs for it circuit board. These nibs need to be removed so that the faceplate will make contact with the old unit's circuit board.
5. Remove the rubber button contact sheet from behind the buttons of the new unit. Find some strong, yet light and thin clear plastic and create a "bridge" between the ends of the buttons. (I used some clear plastic from an old broken EATC that held the smaller buttons in place.) You want clear plastic to let light shine through it to illuminate the buttons. Super-glue the bridge to the back of the buttons on the new unit. Just use a drop of super glue - too much will glue the buttons permantly in place and then you can throw the whole project into the trash. Make sure to test the buttons for movement after they dry. Also, super glue some of the bridge plastic to the small "Blue" and "Red" temperature buttons above the "Outside Temperature" button so that you will have even contact between all of the buttons.
6. Once the bridges are dry, mate the faceplate to the case of the old unit's case. You will find that the old unit's case is a tad wider than the new unit's faceplate and that the alignment studs in the new unit's faceplate will not go into the slot on the old unit's case. Just expand the width of the slot towards the center of the case with a drill until the new unit's face plate will easily fit onto the old unit's case. When fully reassembled, the faceplate will not fit tightly onto the case, so you don't have to worry about the snaps mating properly.
7. Reassemble the old unit's circuit boards back into its case.
8. Swap the new unit's faceplate onto the old unit's face plate circuit board. Remember to retain all of the old unit's circuit boards and display. Position the old unit's button circuit board onto the new unit's faceplate in such a manner that you feel a tactile click with each button.
9. Place the new unit's faceplate onto the old unit's case using the alignment studs. I put small screws into the studs from the back to keep the faceplate onto the EATC case. Leave a bit of a gap between the faceplate and the case so that the buttons will have room to move. If you put too much pressure onto the back of the faceplate, the buttons will always be "on" and the unit will not work properly.
10. Install into your car. I relocated mine to where the stereo head-unit used to be. (I also have the '95 DIN storage bin instead of the flimsy double cup holder tray.) Unlike most people, I placed the EATC behind the stereo double-din trim plate because it looks neater than having the mounting portion of the faceplate exposed and that way you don't have to trim the ends of the faceplace; however, you have to really push to get the EATC into the dash because it is wider than a standard DIN, but once in, there is plenty of depth to handle the EATC. I also duct taped the EATC directly to the trim plate then reinstalled the trim plate. More work, but looks better. :) One thing to note is that the '92 EATC has a larger number display than the new style, so when installed into the new style faceplate, the very top of the display is a little harder to read when the EATC is installed in the head unit DIN slot. (For example the top line of the number 9 is harder to see, so it makes it look more like a 4.)
Hope this helps some one.
- Gil
JoesSHO
Reality
I'm lucky enough to have a '95 now or I'd be looking for one of those for a swap!
Also- when you pull the ****** logos, just jam a small flathead behind it- it may seem like they don't want to come out, but they will. The locking fingers on the back of the logo pull off in one piece- just glued to the logo. Pull that off, clean good and epoxy.
Look around- you may find a larger logo with the "bubbled" face whereas the ****** logo is a "flat" face. Just find one with a similar shape. For some reason, hardly any of them are the same size in different Ford vehicles. Haven't looked at the newer cars, but I think they'd be too large.
Good luck! :thumb:
Minnesho
i was wrong
MinneSHOta
Good luck! :thumb:
I tried one from a 02 super duty and it was way too big, i also tried one from an early gen I slo, 86-88 and it was way too small. I hear if you take one from the door panel of a crown vic and cut it out of the metal plate it will work. I do like the ****** idea though, now of only one could find a yamaha badge that would fit there ...
Minnesho
i was wrong
MinneSHOta
to be honest there is no good way to do it ... the electrical tape is a good idea, but it woud bother the crap out of me... I care about my car enough that I just spent the money on a hard button unit. i think it was like $50 on ebay.
Brad kirk
