Anyone got a 2015 on order?
J5V
Would they automatically do a vin roll without the customer knowing what model year they ordered? I'd assume his order would still be a 15MY unless the dealer said otherwise.
Could also use a window sticker generator too....
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
If you look for the window sticker look for the G 1FAHP2XXXXXXXXXXX in the 10th digit Taurus should all be 1FAH P2 After that they split off
P2K is SHO P2E SEL I believe P2D SE Front wheel drive E SEL Front Wheel Drive P2K is SHO I know that much.
1FAHP2KXXXXXXXXXX
X 8th digit Engine
X 9th digit Check digit.....computer generated random
X- 10th Model Year
X 11th digit Plant Code G= Chicago Note 16 Taurus there could be two spots for G. G for Chicago and G for 2016
XXXXXX 12-17 digit........Plant Sequential assembly order
Starting in 2010 they started the alphabetical numbering system for US vehicles. I believe I O and Q are not used to avoid confusion with numbers one and Zero
A=2010 B=2011 C=2012 D=2013 E=2014 F=2015 G=2016
MerlinsGarage
Eastern PA
If I am reading this correctly production will start the 28th of August.......?
Do they intersperse '15s and '16s down the line at the same time?
PonySHO
FOG
Joe's Garage
My '15 was ordered on 6/6, I was told the build date was 7/6 and it arrived at the dealer 7/16. Before I got a confirmation on the build date, I called Ford Customer Service and was told by two different people there that you can order a '15 till the end of November and production on the '15 would end on December 23rd. I would imagine before they start building the '16, they will need to do some major retooling since it's on a new platform. I'm pretty confused as to what's in production now and when the '16 production begins.
PonySHO
FOG
Joe's Garage
1FAHP2KXXXXXXXXXX
X 8th digit Engine
X- 10th Model Year
Here's a link to the 2015 Ford VIN decoder: http://www.fleet.ford.com/resources/ford/general/pdf/maintenance/vin-decoder/2015 VIN Guide_2.pdf
PonySHO
FOG
Joe's Garage
I checked the build date on the window sticker...
Where did you find the build date on the window sticker? I got the build sheets and all I can decipher there is that it was printed out at 2 AM on 7/9. I was told the build date was 7/6. I'm having a buddy print out an Oasis report so it will definitely be on there.
J5V
At thevery top of your window sticker, there is a blend date. XYYYYMMDD then a larger 4 digit code for line sequencing. As I noted below, my blend date was 7/13, but my car didn't hit end of line until the 17th.
Update: Ordered 6/5. Blend date 7/13, but produced 7/17. Dealer said Monday that they haven't received shipment details from CAP yet...and I haven't been updated since. Really hope it isn't being held for an onsite mod or other issue.
BigB15
GA
Wow, I bought mine on 12/27/2014 as a demo with 2k on it.
Has every option you can get with the PP.
SHO RPh
Tahlequah, OK
If I'm not mistaken the only 2016s in sight at the assembly plant were the two preproduction models they pulled out front for us to look over. It was my impression that the ones still on the line were 2015s. Most of us were surprised at the number of SHOs in the mix coming down the line with the regular Tauri, MKSs and Explorers. It was definitely higher than I would have thought.
I'm wondering if the 2016s will be a short run, with the new platform coming out as a 2017 in late spring. It's been known to happen when they update to an all new version of a previous model.
PonySHO
FOG
Joe's Garage
Curious, mine doesn't have any numbers at the top. The dealer told me the build date was 7/6. When I got it, the build sheets had a printout date of 7/9 at 2 AM. I had a buddy print out the Oasis report and it has a build date of 7/9.
J5V
That sounds right. At the end of the link below, add your VIN. It will pull up your window sticker with the date info I mentioned. Blend date at the top along with sequence number.
http://fordlabels.webview.biz/webviewhybrid/WindowSticker.aspx?vin=
J5V
No problem. I'm still waiting on my car....ordered 6/5 and it was built on 7/17. No ship date yet from the salesman. Not too thrilled. Hoping it's just because of the seats (suede + multi contoured) and its not sitting in a lot waiting for a mod.
